Computer_Freak
Ok which is better.
I am leaning towards teh CM because im not a fan of Acrilic sides (retains heat for longer and my comp is not that neat inside (although i will try fix that))
Now i want something that i wont need to upgreade again, that has very good air flow and that looks good and has good cable management.
I read that you need long cables for the Antec.
Now can someone please list the pro's and con's?
ANTEC 900
Pros
Very good cooling
Price
Bottom PSU (gets cooler air)
Cons
Side panel (acrylic)
and no fan directly opposite CPU (If i have normal heatsink (not like the Zalman 9700) it helps a lot.
Small Interior
Bottom PSU (need longer cables?)
Very bad Cable management (reason why i dont want a acrylic window)
Coolermaster CM 830
Pros
Looks much nicer
Large workspace
No side window
Mesh sides (on mobo side helps cooling)
Many side fans incliding one directly opposite CPU HSF
Cons
Price ($65 more)
Now i pretty much answeres myself. But it would be nice to hear what people say.
Also can you put front fans on the CM 830 (if you remove DVD drive covers) or is there just that one front mount.
ANTEC 900
Pros
Very good cooling
Price
Cons
Small Interior
Coolermaster CM 830
Pros
Looks much nicer
Large workspace
No side window
Cons
Price ($65 more)
