camel lips
Anyone know a good free program that will tell me what temperature my laptop is running at?It seems to be getting too hot.
Its a HP ZE 4900 with Celeron 1.33
links?
Fan is working,allthough it use to come on a lot more than it use to.Seems like when I first got it ,it ran all the time.Yes, that's high for both, though the HDD can stand higher temps than a Desktop unit typically can. Is the CPU fan working? Is the heat-sink or went grill covered by dust? That could explain the high CPU temp.
i hope those temps are in F and not C
i like rightmark cpu clock utility. you can have it start up minimized in the taskbar, and it shows you core temp and cpu clock speed.
also, clearinfo is a good program to monitor all around settings. it is embedded in your desktop so you can see all your info on the fly.
as far as temps go, 60c is getting hot, 70c is bad for the cpu, and 80c will kill your pc in a matter of days.
oh mine was rocking 79c for a good few hours? i take it that aint to good? i need me some compressed air![]()
