K Knild New Member Mar 1, 2008 #1 Hi guys. I have 2,752.50 USD and i wanna buy a computer that's compatible with the PC game "crysis" in "Very High Settings" I want dell computer // Knild
A anothEr New Member Mar 1, 2008 #2 Go for the xps laptops. They are quite nice when it comes to gaming.
hpi banned Mar 1, 2008 #3 Sorry but a Dell XPS will NOT run crysis maxed. With that money you can build yourself a very good computer that can maybe max Crysis out. I don't really feel like finding parts and all so Il leave it up to the ones who don't mind
Shane Super Moderator Staff member Mar 1, 2008 #4 nope i doubt an XPS will max it out...i heard from here you need at least 2 Ultras to max Crysis out with decent fps
voyagerfan99 Master of Turning Things Off and Back On Again Staff member Mar 2, 2008 #5 Knild said: Hi guys. I have 2,752.50 USD and i wanna buy a computer that's compatible with the PC game "crysis" in "Very High Settings" I want dell computer // Knild Click to expand... *Drools* Wana pass some of that cash my way?
BluePlum banned Mar 2, 2008 #6 I have the lastest ell XPS and it cant max out crysis. If you can build a computer go for that. But if you want a dell get the XPS but cant max crysis out.
K Knild New Member Mar 2, 2008 #7 so what should i buy then? and do anyone know the specifications for crysis in ver high settings? Last edited: Mar 2, 2008
Kill Bill Active Member Mar 2, 2008 #9 Get the alienware 15x I think. It has Intel Quad,8800GTX 512mb etc
hpi banned Mar 2, 2008 #11 Kill Bill said: Get the alienware 15x I think. It has Intel Quad,8800GTX 512mb etc Click to expand... LOL you think that's gonna run Crysis? Heres something that should : cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115026 Gpu (x2) : http://www.newegg.com/Product/Product.aspx?Item=N82E16814143093 Ram : http://www.newegg.com/Product/Product.aspx?Item=N82E16820227280&Tpk=4GB+OCZ+Platinum+PC2+8000+DDR2 HDD : http://www.newegg.com/Product/Product.aspx?Item=N82E16822148152 Pysx card : http://www.newegg.com/Product/Product.aspx?Item=N82E16814143055&Tpk=Ageia+Physx+Card Psu ( either of these ) : http://www.newegg.com/Product/Product.aspx?Item=N82E16817341006 http://www.newegg.com/Product/Product.aspx?Item=N82E16817341007 Mobo : http://www.newegg.com/Product/Product.aspx?Item=N82E16813131074 OR Psu : http://www.newegg.com/Product/Product.aspx?Item=N82E16817341007 Mobo : http://www.newegg.com/Product/Product.aspx?Item=N82E16813131074 Cpu : http://www.newegg.com/Product/Product.aspx?Item=N82E16819115026 Ram : http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85026-3 HDD : http://www.newegg.com/Product/Product.aspx?Item=N82E16822145141 Gpu x2 : http://www.newegg.com/Product/Product.aspx?Item=N82E16814143093 Physx card : http://www.newegg.com/Product/Product.aspx?Item=N82E16814143055&Tpk=Ageia+Physx+Card You wanted to know, heres your answer to what Im pretty sure can run Crysis maxed out or very close to maxed out completely. Edit: Running Crysis on a laptop is just not good, that things gonna heat up sooo much. Last edited: Mar 2, 2008
P PabloTeK Active Member Mar 8, 2008 #13 There is one laptop that *may* be able to run Crysis well, it's from the U.K. though and costs quite a lot, here it is! http://rockdirect.com/viewNotebook.php?pName=XTREME SL8 SLi 8800GTX Mobile's, desktop CPU etc.
