Need help on building desktop
Campo
banned
OK so i'm thinking of building a awesome comp slowly eg. buy this here, something else there, space it out over a few years.
So i'll need everything but I just need some help on what to buy.
Must-Haves:
500GB HDD
DVD Burner
So what do you think my build should be?
Thanks,
EDIT: I plan to play COD4 and rFactor on it and maybe some more games like those
EDIT2: I'm in australia so the prices in AUD would really help
Well, you should look at getting a Dual Core CPU, A DirectX 10 card, 2 to 4gb of Ram, then whatever you have in the must have list.
Dont buy from the shop i am posting i will give u AUS prices from a store called MSY
CPU $228
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
Motherboard $139
http://www.gigabyte.co.nz/Products/Motherboard/Products_Overview.aspx?ProductID=2741
Caes $153
http://www.thermaltake.com.au/Products/Chassis/VG6000BWS/SopranoRS100.aspx
PSU $156
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371001
hard drive $132
W.D. SATA 500G
Vid card $275
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125086
Ram get 2x2G DDR 800MHz sticks it will be about $100
that is $1183
will play any game.
hears where u can see the price list for MSY an where your closest store is.
http://www.msy.com.au/Parts/PARTS.pdf at the top is where the stores are.
Thanks mate. Haven't had a look through them yet because I have to go to school.
I'll look after school.
Thanks again.
Does everyone else think this is the best thing to do?
Not go to a shop? Yes.
Go and build it yourself? Yes.
CPU - E8400
Motherboard - P35-DS3L
RAM - 2GB DDR2-800 CL4
CASE - Antec 900
PSU - OCZ GameXStream 700W
OPTICAL - DVD Burner PATA
GFX - 8800GT/8800GTS G92
... Something like that.
1. - ASUS M2N-MX SE - $59 - http://www.asus.com/products.aspx?modelmenu=2&model=1647&l1=3&l2=101&l3=345&l4=0
2. - AM2 x2 4400+ - $92 - http://www.digitalyes.com.au/prodView.asp?idproduct=38620
3. - Seagate SATA 500G - $156 - http://www.seagate.com/ww/v/index.jsp?vgnextoid=b9df99f4fa74c010VgnVCM100000dd04090aRCRD
4. - 2G Kit-800 (2x1G) Kingston - $55
5. - ASUS Retail Lightscribe 18x IDE - $39 - http://www.asus.com.au/products.aspx?l1=6&l2=35&l3=0&model=1488&modelmenu=1
6. - F1 RACING Red / Yellow Case - $85 - http://www.advancetec.co.uk/acatalog/f1_racing_s.jpg
7. - 512MB 8600GT Generic - $85 - http://www.macotechnology.com.au/pr...227&pdone=1&showpd=0&showpd2=0&showpd3=8600GT
Total - $571.00
Or a Thermalmaster case - Thermaltake Wing RS-100/RS101/Matrix $91/95/99
Thermaltake Soprano / SopranoVX / BachVX $121 / 121 / 166
http://www.msy.com.au/Parts/PARTS.pdf - Has all the stuff and information fo the latest price list.
Total - $571.00
Your using Austalian and UK sites... :confused:
I'd get more than a 8600, but that's just me.
The sites are for the specs and that is what they were there for and the prices are from MSY and the price list link is there.
