hells3000
Intel Pentium E2160 Allendale 1.8GHz LGA 775 65W Dual-Core 73$
Corsair XMS2 2x1GB 29$ with coupon and 40$ rebate
GIGABYTEGA-P35-DS3L LGA 775 Intel P35 ATX All Solid 80$
BFG Tech BFGE85256GTE GeForce 8500GT 256MB GDDR2 PCI
Ok I have a hdd (1.5), The PSU (Thermaltake TR2 W0070RUC ATX 430W)
Case, OS . MOUSE, KEYBOARD. MONITOR,
What am I missing?
What can I change?
Will that psu handle the system?
I don't plan in ocing
Ram/GPu are sli
Should I go for a sli mobo?
Will the sata 1.5 on the mobo 3.0 be an issue? (I do have a 1.5 sata controller card)
Will windows xp have an issue with the mobo?
This is from Gygabite's Site :
To enable hot plug capability for the SATA connectors controlled by the ICH9 South Bridge, you must install Windows Vista (on ICH9, hot plug is supported in Windows Vista only) and configure the SATA connectors for AHCI mode. (Refer to manual Chapter 2, "BIOS Setup," "Integrated Peripherals," for details on enabling AHCI.)
What am I missing?
What can I change?
Ram/GPu are sli
