Win98 or SE
Just says 98. Also should I buy the upgrade or the one for pc without os'es. Also will the upgrade version work for vitrual pc 2007
Ok. So! How do I just format the laptop! Do I reboot and enter a commend or something. Give me give me instructions:P
To install Windows 98, you need to boot from the floppy drive using a startup disk. Then, select the "Enable CD-ROM" support.
You can download the files to create a boot floppy Here. Just download and extract to the desktop, then copy the contents of the folder onto the floppy. Then, reboot the system and it should boot directly to the A:\ floppy.
To format the drive once you have the floppy setup and whatnot, you will see "A:\> and you just type "fdisk" (without quotes) and delete the first partition on the HDD (if you don't have anything on there you need). Thenm create a primary partition and an extended partition. Then, exit FDISK and reboot using the floppy again. Enable CD-ROM support and then when "A:\>" appears, type "D:\" (without quotes) and then type "Install" and the rest is easy! Just follow the instructions.
the old 98 laptop has a usb port. But what would I do. I can't get the net on it;) Is it simple just to reboot and do a command prompt or something
I'm going to buy a win98SE for it but its distrubuton for pc without OS I.E formating.
It comes with this:
Unopened
Pack is complete with -
Windows 98SE Boot Disk,
Windows 98SE Holographic CD,
Windows 98SE Starts Here CD,
Windows 98SE Getting started manual
Windows 98SE Certificate of Authenticity
Does the holographic cd mean the OS itself thingy.
The holo-CD has the OS on it,yes. What I'd do to load it is to place the boot disk in your computer and copy the contents to a spare flash drive. Then plug it into the USB port on the lappy and set the BIOS to boot from the flash drive. (It should be able to do that under "Other". It MAY work, but I'm sure. I've never tried to boot from a USB flash drive.
Still it has no intenet and the plug & play loves drivers;)
I'm buying the os for pcs without 'em so can I use it on the 98 laptop and install it as a repair or something or at bios set it to boot from cd and go from there;)
Well I didn't know if you were able to boot from the CD on your computer. You never gave specifics :)
Here
All I know is ths:
It's a gateway 2000 SOLO. It has Bios.
It has: Pentium MMx 166MHz 128mb Ram 1.99GB HDD Win98 1st edition;)
so i found this post and tried following the instructions exactly to get my old windowns 98 remformatted...ran "fdisk" deleted the "1 dos partition"
created new partition..it said restart so i restarted it, i'm not getting A:\ anymore and therefore cant type in the comand to get it to boot the cd...help please!!!!
if you cani suggest getting a bigger hdd, or else you will keep getting messages of disc full, do the disc cleanup, i have a 2gb hdd on my laptop, that message is so annoying
