Monitor problem
Shane
Super Moderator
Hey,
I have this monitor:
22" Belinea 0 Display LCD 5ms
http://www.cclonline.com/product-info.asp?product_id=18486&category_id=364&manufacturer_id=0
this past week i have not been able to turn the monitor off while the pc is running like usualy if im downloading and i want to go out i will leave my pc running but just turn off the monitor but i cant because when i press the monitors power button i get a message on the screen that says:
"Power button locked"
Any help appreciated.
cohen
Sounds like it is a problem with the button on the inside of the monitor.
So you might have to open it up and have a look or buy a new one.
TFT
It's not a problem with the button it's a feature to stop accidently turning the monitor off. This is set in the OSD menu which can also be locked.
Shane
Super Moderator
wheres that OSD menu mate i have no clue.
i dont know why its locked because i havnt been messing about with any of my monitors buttons or anything.
it just wouldnt switch off since Monday :mad:
TFT
Try these options, they are'nt for your LCD and the wording/symbols may be different but may unlock your buttons, if not try a few combinations, you get the idea.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Shane
Super Moderator
compleatly forgot about this post, itried turning my monitor off just and got the damn message again.
this worked...
"MENU"
tks so much man ;)
