video card question
yes you could get an aftermarket one to put on it.. but why do you need it? are you planning to overclock it heaps?
even so the stock heatsink should be able to handle it
ok thanks .ya i planned on overclocking a little bit i just thought the fan that came with it looked a little small
yeah well it should be fine...
my 8800GT stops being able to overclock higher long before heat becomes a problem..
no problem. of course if you decide you really want one then post back and ill try and find one.
have to go out now so will be a little later tho.
