Here's the main specs for what I plan on getting, hoping that the local store has the stuff in stock that it says online:
CPU: AMD Athlon 64 X2 6400+ (125W) Dual-Core Socket AM2, 3.2GHz, 1MB x2 L2 Cache, 2000MHz HT, 90nm
<or>
AMD Athlon 64 X2 5000+ Black Edition Dual-Core Socket AM2, 2.6GHz, 512KB x2 L2 Cache, 2000MHz HT, 65nm, WOF (and overclock this)
Not too sure which to go with, any input would be great. I realize I would need a heat sink/fan for the black edition.
MoBo: Asus M2N-E Socket AM2 nForce 570 Ultra MCP Chipset DDR2 533/667/800 6xSATA PCI-Express x16 Slot 7.1 Channel Audio Gigabit Lan AMD Live! Ready
GPU: Sapphire ATI RADEON HD 3870 512MB GDDR4 Dual Dual-Link DVI HD Audio Shader Model 4.1 320 Unified Shaders PCI-Express 2.0 Graphics Card
PSU: Cooler Master Extreme Power 550W ATX 12V V2.01 Silent Power Supply 20/24PIN 120MM Fan
RAM: Transcend JetRam DDR2 PC2-6400 800MHz 2GB (2x1GB) Kit
HDD: Seagate Barracuda (ST3160815AS) 7200 SATA NCQ 3.0Gb/s 160GB 8MB Cache (OEM)
Disk Drive: LG GSA-H62N(Black) SATA DVD-Writer 18x DVD+R/-R 8x DVD+RW/6x DVD-RW 10x DVD+/-R9 Dual Layer 48x CD-R 32x CD-RW OEM
Sound: Creative Sound Blaster Audigy SE 7.1 Surround 24 Bit 96KHz EAX2.0 Sound Card (OEM)
Then a case and some fans and a network card. Comes out to about 750ish. I can get Vista Business for $25, or XP Professional SP2 for Free, so I don't know which to get. Let me know what you think, I'm open to all suggestions as this is the first computer I have ever planned to build.
<or>
