MSN Messenger 8.5
katulu50
Hi, Im looking a msn messenger key logger that let me know all the conversations in my machine, it's not necessary to have a remote control but to be able to save all the conversations in my machine, also that this software works with MSN messenger 8.5 for Windows Vista. Thanks.
Key Logger, I don't think you'll get any help with that here dude...
BUT, MSN has a feature that allows you to save all the conversations, which is exactly what you're after, right!
Yes msn does have a feature that saves your conversations, i'm not sure of how to enable it..but i do know that after you install msn messenger 8.5 the first conversation you have should have a window pop-up that asks you if you would like to save your conversations but it does say "Saving conversations is not recommended on a shared computer" or something along the lines of that. Hope this helps :)
