Like I figured your not going to answer the question. PCeye if you cant swim stay out of the pool, your sucking water and flopping around screaming but telling everybody its just a new way of swimming called the Water Sucking Backstroke.
The WD software doesn't install any usb drivers while those items can be plainly seen.
Cute screenshot, this is the third time I am asking the same question and you still havent answered. HOW DOES REINSTALLING YOUR USB DRIVERS AND DELETING OLD USB DEVICE DRIVERS TRASH WINDOWS. I am really curious because I,ve done it many times.
If you haven't figured it out by now you never will.
On a recent fresh install of XP everything in the usb section of the device manager had a nice yellow mark next to it. Yet the external drive was readily available when plugged in even while the auto run was busy.
Once reformatted from Fat32 to NTFS the auto run is simply a waste of time as well as uninstalling usb listings in the DM. Plus you're telling someone that may know nothing at all about how to go about things in the DM and instructing that person to simply start uninstalling things?real smart genius!
Start smeilling what's on your shovel.
All that before Pauly73Drifter could even be asked how old the system with the ide actually is. hhmmmm.... Some old case with only 1 or 2 usb ports and not enough milliamps on the usb bus like the WD support site indicated as one actual explaination. That's they seem to carry a usb current booster for older systems.
All that looks good on the surface but it means about as much as the price of grapes in China pertaining to the question. I can see how you fool noobs with your reworded google look ups and on and on rambling of brilliance. I never questioned the milliamps on the USB hub. For the fourth time. (How does reinstalling your USB drivers and deleting old USB device drivers trash Windows?) which could be causing a problem on a equal basis and I never said to just start uninstalling things. Quit twisting things and just answer the question.
I did answer the question but you as usual never bothered to "listen" which is nothing new for you either.
As explained earlier the entire usb section was yellowed out on a fresh install of XP when that was seeing a custom later being reinstalled all over to see that corrected. Couldn't get online with the usb host controllers out but the external drive was still seen as a logical without even reinstalling the WD software.
Figure it out yet? When reformatting the original Fat32 to NTFS the software and auto run is no longer if you have it plugged into a working usb port or the usb bus sees at least 1000uA meeting the minimum requirement. Is it that difficult for you to figure out?
Windows then readily sees the drive as simply another sata model just like the bios recognises it right off. With the clean install of XP Windows didn't have time to even see the usbstor.sys be installed as the auto run popup prior to the installer was busy while the drive was seen in Windows Explorer upon reaching the desktop. Had to fight to close those out when they persisted since the drive was already a logical drive.
I smell a fresh load of feces.. *sniff* *sniff*
Any fresh install of XP detects the USB ports and installs them. The only exception is pre-sp2 on USB2.0 controllers. Then again, this is Flinstone we're talking about here.
AND.. If Freddy did use an archaic version of XP on USB2.0 controllers, they would STILL work although they would indeed have the yellow !. They would simply work as USB 1.0 controllers.
I usually just pull it out and plug it back in once the new hardware bubbles stop popping up.The same "USB device not recognized" message also occurs with mice, USB keyboards, etc. Resetting the computer by pulling the power from it for five minutes is a well documented trick to resetting the USB ports.
Well this thread is a peice of work.
We don't know if the drive is spinning up or not on the second machine, it's possible it's not able to draw enough power from the USB port. To know for sure we'd need to hear back from Pauly73Drifter.
Reinstalling the USB hub drivers (ie uninstall & then install again) wont damage a windows installation unless there are other problems. All your USB devices will redetect. Now if you only have a USB keyboard/mouse it might get a little dicey although I'm pretty sure it's still possible, I can't remember the exact process for windows to install hub drivers (whether you have to click through menus or not).
