Hi everyone, noobie here.
I am trying to build a gaming computer on a budget, I am trying to keep the total cost below $550.00.(not much I know)
I already have the monitor,mouse and keyboard,sound system, and a friend has some ATX cases I can have so I think I can get the following and still stay in budget.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128081
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103228
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339012
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220144
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151155
http://www.newegg.com/Product/Product.aspx?Item=N82E16825164001
Is all of this stuff compatible?
What else do I need?(if anything)
Also which video card would be best for gaming?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130332
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130290
EDIT:Or would this card be better?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150277
And do I need a aftermarket CPU fan or will the one that comes with the CPU work?(I don't plan on doing any overclocking)
If I do need a CPU fan are there any good ones in the $25-35 range?
Sorry for all the question, I'm new at this.
Thank you for any info.
Michael.
Michael.
