Centurion 534: Extra Fan?
The fan in the front to cool the hdd is a very good idea.
However the one under the air funnel won't really help to much i think. You would be better of taking off the air funnel and getting a better heatsink (if you don't already have one). I'm not a big fan of air funnels anyway.
the 80mm fan under my air funnel helps heaps.
cos theres like twice as much air being blown onto the cpu.
but yes you would be better off with an aftermarket HSF.
A lot of that is case/cpu-specific, though. I tried it with my setup and all I got was maybe 1-2*C lower temps and a whole lot more noise. It did sound cool for a few minutes because of the 'draft' effect though:)
With a fan/funnel setup, it's definitely one of those YMMV things.
i sorta have a similiar thing, like i had a air vent, i replaced it with a fan and the fan is an exhaust. should it be an intake or whaat?
yeah it has to be intake. cos otherwise it is sucking air when the cpu fan is pulling it in. i did that at first and it was horrible haha.
