Respital
Oh ok i didn't see it on newegg or canadacomputers so i thought u were thinking about the 780i anyways i'm making the new list now.
Watts do matter, but it's a combination of wattage and amperage. Generally though you won't find a power supply with high amperage but low wattage, so it shouldn't be a huge concern.Well the watts does not matter so much on a power supply it's the 12V rails that matter the more A the better for example 50a is better then 20a. yes thats ram would be good. As for a cheaper mobo (short for motherboard) I suggest you go with the Giga-byte P35 DS3r Or P35 DS3L the only difference is the number of sata ports.. i think..But you will not be able to run more then one graphics card on either of them
Link To Giga-Byte P35 DS3L : http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
[-0MEGA-];925960 said:Watts do matter, but it's a combination of wattage and amperage. Generally though you won't find a power supply with high amperage but low wattage, so it shouldn't be a huge concern.
ok so is that the absolute cheapest power supply
and is the mother board just as fast and just as nice and everything well is everything the same
ok so that one dvd burner from the guy whos name escapes me and the hard drive from him also that is 65 dollars there that motherboard for 90 bucks
the corsair dual chanal twinx RAM is 35 dollars the atec 900 or the Xylio(i think i forget the name) windtunel for a case there both 120 bucks
and a power supply i am still looking for a cheaper one
also which processer are we going to use
so far it is $310
