Ram Density?
THEAVS
I'm a little confused so here it goes. From what I understand, my motherboard has a Max Component Density of 512. Would ram with an arrangement of 128x4 (high density) work with my motherboard?
What make and model board is that seen for? It should be listed as a maximum amount of memory being 512mb for old board. Sometimes the user manuals can be a little goofy at times on how things are worded. Ram density refers to the capacity or size of a memory module whether simm or dimm.
For DRAM memory that would be megabits while megabytes is used to refer to the entire simm or dimm size. When buying memory for a board you first want to know the size and type as well as speed of memory it supports. For an board seeing 4 slots you would likely see 128mb as the largest size of simm(single inline memory module) installed unless the board allows for 256mb modules.
Is a MSI (Micro Star) MS-6566 (845 Ultra-C) mother board. Would this http://cgi.ebay.ca/ws/eBayISAPI.dll...em=260219893955&_trksid=p3984.cTODAY.m238.lVI work?
I honestly don't know if it will be compatible with your chipsets thats why it always pay to buy low density memory.
Boards expecting memory to come in 64M bit high and 8 bit wide chunks (low density) isn't happy to see memory 128M bits high and 4 bits wide although the total memory is the same.
Try it and hope that you don't get any post beeps
My computers manual says that it takes DDR DIMM with 4 memory banks. Does this mean that it will work with ram configured 128x4?
No. Banks are something else.
The chipset specs only mentions valid configurations of 512 Mbit density with x8 and x16 chips. That module has a density of 1024 Mbit.
What you've just posted doesn't tell you anything, as I said some motherboards will not accept high density, ASUS being one of them yet others can tolerate high density. High density chips are inferior and sold on Ebay for much lower prices but most times are not advertised as such.
Unless someone can pin down your board more accurately then it is a case of "suck it and see"
