vista.. how can i tell what sp i got?
Sp1 has just come out for vista it is quite a big download but i would recommend getting it because it just might improve the stability and compatability of the os with other programs.
can you give me a direct link to download sp1 for vista? and while installing it.... do i have to reboot? and do i still be able to listen to music while installing?
Come on, what's more important, downloading an update or missing a bit of music for a while. Turn on the radio :rolleyes:
It's only around 66MB via Windows Update, and yes you will need to restart. Just have it install and then come back an hour later and it should be done. Try not to do anything else when it's installing.
I found vistas windows update is wierd..i once came across it saying install service pack 1 but i thought i best restart first as i had installed other programms...then when i went back to the windows update programm it said everything is up to date! Took me 5 rescans to be able to choose to update to service pack 1..
