Sounds like it's Recuva time again for someone. http://www.recuva.com/ That's a freeware while something like Active Undelete is a retail software. And before all the lame remarks start pouring in I'll show you an alternative method for seeing files copied from drive to drive without Windows even running.
A live for cd distro can get around bad sectors and MS errors at times like ubuntu 7.10 seen there.
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted by bugs, crashes and viruses!
The advantage of a live distro is that you can get past obstacles at times since Linux uses a different way to access partitions whether they are MS, VFat, or another type without any particular OS being loaded except for the live session which is a self contained OS on a cd-r and not running off of any hard drive.
One old article explains how to use the Debian Distro Knoppix for the same type of recovery when a drive or partition can't be accessed normally unless the drive is more then seeing bad sectors but the heads are going on you. http://www.shockfamily.net/cedric/knoppix/
When booting with a live distro simply press the enter key to see the defaults loaded unless you are a more advanced user.
drive is not toast yet Pc_Eye, its still good, and no i cant afford to send it to professional recovery serviceIf you are seeing that type of error with a live distro where it can't even view the drive it's likely that the drive is toast and the only thing you would be able to do is send it to a professional data recovery service. If the hardware portion of the drive is working the way it should you would have seen the drive as a desktop icon like seen in the screen shot taken while booting up with ubuntu live here.
well right now i was about to Install Recover my files, ive been reading on google that its ok, though not freeHere you go
Recover my files application no need for installation
Here is the link to download it from - Download File Here
When did you last use the Linux disks? If you are now using a different optical drive then the one the disks were burned that will often account for disks not being read or to load up properly. I've tossed a few frisbies here recently when old backups on cd-rs could no longer be read.
