I-KILLED-U
Say you have 350 to 400$ to spend on a digital camcorder. which type would u get,
MiniDV or Internal HD?
Internal HD
More reliable for a HD.
No need for disks etc.
Easy transfer
Hey do you whats the difference between USB and Firewire cable when it comes to HDD camcorder?
Yes,
I'm pretty sure Firewire it quicker. But i think you have to have a Firewire port on your computer or at least a converter. But otherwise USB should be fine. Shouldn't have a problem with either of them.
But what i have just read on a google search it may be only a mac port for mac transfer only.... It also says the it is faster and i believe that is right!
But here is a link
Good Luck
Edit - I just had a look at the pics and i'm pretty sure the newer motherboards.
thank you
