jutnm Active Member Mar 24, 2008 #1 what are some mid level boards that support AMD chipsets. boards that are like 6 months new out on the market. and what are some CPUs by AMD that are new ? but with in the price range of 200 $ and lower ?
StrangleHold Moderator Staff member Mar 24, 2008 #2 On Motherboards it depends on what you want to pay for it. Anywhere from http://www.newegg.com/Product/Product.aspx?Item=N82E16813128081 http://www.newegg.com/Product/Product.aspx?Item=N82E16813136044 http://www.newegg.com/Product/Product.aspx?Item=N82E16813136041 On processor the X2 6400 is about 176 bucks http://www.newegg.com/Product/Product.aspx?Item=N82E16819103191 The 9500-9600 is 189-229 But I would not buy a AMD Quad now or not till atleast the B3 stepping comes out. http://www.newegg.com/Product/Produ...&Subcategory=343&description=&Ntk=&srchInDesc=
jutnm Active Member Mar 24, 2008 #3 StrangleHold said: On Motherboards it depends on what you want to pay for it. Anywhere from http://www.newegg.com/Product/Product.aspx?Item=N82E16813128081 http://www.newegg.com/Product/Product.aspx?Item=N82E16813136044 http://www.newegg.com/Product/Product.aspx?Item=N82E16813136041 On processor the X2 6400 is about 176 bucks http://www.newegg.com/Product/Product.aspx?Item=N82E16819103191 The 9500-9600 is 189-229 But I would not buy a AMD Quad now or not till atleast the B3 stepping comes out. http://www.newegg.com/Product/Produ...&Subcategory=343&description=&Ntk=&srchInDesc= Click to expand... thankyou and much appreciated for ur help ") im thinking of building a new computer
