Final ~$2000 build list
Because I want DDR3 memory for the future.
Okay. Do you plan on upgrading to speeds greater than or equal to 1600 MHz? If not, you should get the 780i and some good DDR2 RAM. :)
And the 790i ultra has better support for 45nm cpu's.
Are you referring to the native 1600 FSB support? Do you plan on buying the QX9770 in the future?
Well the mobo says it can support ddr3 up to 2000 MHz, so in time when this one starts to bog down it's good to know there is plenty of space for more performance.
Well I plan on upgrading the CPU when I need to. A Q6600 is fine for now, but 2 years from now I might need more firepower and it's nice to know this mobo has plenty of head space for upgrading.
The prices on DDR3 will obviously decrease, so in a year (maybe even six months), you should be able to get something fast and affordable in the RAM area.
Two years from now that CPU socket will be obsolete. :)
The only differences between the 780i and 790i are DDR3 support and the native 1600 FSB (and one onboard eSATA slot). The 1600 FSB doesn't matter since you're getting the Q6600. Anyway, it looks like a good board and the rest of your build looks awesome.
Good luck. :)
Maybe so, but the best Yorkfield chip will still be a huge upgrade from my Q6600 Kentsfield, and by the time I need it, I'm sure it will be much more affordable as well. I just think the setup I have listed above is a powerhouse now, yet still has huge room for upgrades, thus futureproofing myself atleast for a while.
My current PC is a Gateway 450 that I got as a freshman in college 5 years ago with a p4 2.0, 1 gig of ram and a 128 geforce 4400. So If I can squeeze 5 years out of that one, I'm sure I could get a similar lifespan out of this build, especially with all this upgrade capability. And let's not forget that the 790i ultra SLI also supports triple SLI as well.
Fair enough.
I see what you're saying. Before I built my first rig, I was running similar specs.
The 780i supports Tri SLi as well. You know, the 9800 GTX is suppose to debut the first week of April. In fact, it's already for sale in Germany ( Link ). It's suppose to be around $349 here in the US. That would be better than the GTS, in my opinion.
