My New Computer
jutnm
CPU- AMD Phenom 9600 Agena 2.3GHz 4 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 95W Quad-Core Processo -$230.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103244
GPU- EVGA 01G-P3-N891-AR GeForce 9800 GX2 1GB GDDR3 PCI Express 2.0 x16 HDCP -$600.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130338
MOTHERBOARD- ABIT AN-M2HD (LE) AM2+/AM2 GeForce7050PV/ nForce630a HDMI Micro ATX AMD Motherboard -$85.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127036
MEMORY- CORSAIR XMS2 DHX 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - $139.00 X2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145194
POWER- Antec NeoPower 650 Blue ATX12V / EPS12V 650W Power Supply - $100.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371010
4 all the 4gig to show, remember u need a 64-bit os. thats one helluva expensive gpu! What case are u going to get? and i hear that the intel quads r better then the Amd's. actually i havent, but ive hear that the phenom was a flop.
Spending $600 on GPU, with a crappy phemon 9600 and Abit Motherboard?
I'd rather get Q9450 + P35 + 3870x2
If you are supporter of AMD, buy Phemon a bit later when their B3 stepping Phemon (9x50) are out.
And get better motherboard with AMD 790FX chipset, which support CrossFireX (4 x PCI-E 2.0), e.g. ASUS M3A32-MVP Deluxe/WiFi
Then, get 2 x HD3870 in crossfire or HD 3870x2 rather than 9800GX2.
9800GX2 performs better than HD3870 X2 specially when running AA
And 2x HD3870 X2 doesn't perform a lot better than HD3870
Q6600 is faster than any phenom, check the benchmarks
http://anandtech.com/cpuchipsets/showdoc.aspx?i=3272&p=1
True, but I am assuming he have $900 for his GPU + MB + CPU.
If spending 600 on GPU, which leave him $300 for MB and CPU. A $100 MB is not really good. Anyway.
Also a 3870 is now $170. So $340 for 2, $510 for 3; plus he is a AMD fan.
Edit: I am not saying Phenom is better than Q6600. We knew they are not. Just because he is a AMD fan, and thus he want Phenom.
+1 Going all out on the gpu and cheaping out on everything else is not a good idea, stay within your limits, spread your money out and you will be better off in the end.
