Kornowski VIP Member Mar 26, 2008 #1 Is this a good OC for my card? I have it running at; 775/1920/1035 Here's a comparison between mine and stock;
nffc10 Active Member Mar 26, 2008 #2 That's not bad mate. I'm not sure how well those cards overclock so i can't say whether it's good or not, however it seems pretty good. Oh, for some reason when you overclock the card on GPUReview, the Flops doesn't calculate for some reason.
Kornowski VIP Member Mar 26, 2008 #3 Yeah, I kind of noticed that with the flops I guess it's pretty good, I'm not sure if I could go further or not...
Kornowski VIP Member Mar 26, 2008 #5 taylormsj said: Only one way to find out ... Click to expand... Play Crysis?
M m0nk3ys1ms Active Member Mar 27, 2008 #8 Kornowski said: It wasn't stable Click to expand... I would try backing off the memory a bit, but keeping the core.
Geoff VIP Member Mar 27, 2008 #9 It's alright, but the memory overclock seems pretty low, but I guess for GDDR3 it's cutting it close already.
Kornowski VIP Member Mar 27, 2008 #10 m0nk3ys1ms said: I would try backing off the memory a bit, but keeping the core. Click to expand... Any reason? I've noticed a small increase in performance, don't know if it's actually worth it...
Kornowski VIP Member Mar 27, 2008 #12 taylormsj said: Get atitool to test for stability Click to expand... I have it...
M MosIncredible New Member Mar 27, 2008 #13 My first time reading about that program. How long should you run it for stability? I made it to 21 mins with the clocks in my sig and stopped it. 56c was max temp.
T taylormsj New Member Mar 28, 2008 #14 scan for artifacts, and if you get no beeps, artifacts or yellow dots on screen for an hour or more, than you should be fine
