Hey guys, was wondering if anyone can help me out.
Just put together my new build yesterday, so far as i can tell everythings connected ok (i even checked the various manuals ;P), but when i power up i just get a continuous beep out of the case speaker. I'm guessing thats supposed to be a warning of some kind although theres nothing about it in the mobo manual, and it goes on forever (afaik anyway, i've never kept it going more than 10 secs or so). No signal to the monitor either.
Build:
Thermaltake toughpower 750w modular psu
ASUS P5N-T Deluxe 780i
Intel Core 2 Quad Q6600 w/Zalman CNPS9500A
Corsair 4GB Kit DDR2 800MHz/PC2-6400 XMS2 Memory (2*2gb)
Seagate 500GB Hard Drive SATA II 7200rpm 32MB Cache
EVGA 8800GT 512MB (possibly gonna use step-up to get a 9800gx2/gtx when i've seen some more reviews, assuming i can get the build working ;p)
Sony Sata 20X DVD-RW
So far i've checked all the connections are in fully (and that i havn't forgotten about any), swapping the memory round to the other channel and using just one stick (although afaik a problem there wouldn't cause this), tried the gfx card in the other pci-e slots, and systematically disconnecting the hdd, dvd-rw ect to see if any of them are causing this somehow. Even does it with the gfx card and ram out. This isn't the piercing beep the 8800s give when they don't have their power cable connected.
Also worth noting is that none of the fan connectors go into the motherboard, but through a Sythe fan controller in a 5.25" bay at the front, which is powered from a regular molex straight from the psu. I figured the tone might be a warning triggered by the mobo not detecting a cpu fan so i plugged the cooler straight into the socket on the mobo. No joy there.
Anyone got any ideas? Cheers in adv
Build:
