google virus?
dieferbiefer
Every time I try to go to google.com it redirects me to google.es, but if i go to a proxy then type google.com it takes me to google.com like it should. I think i might have a virus that put a refrence on my computer to google.es, is this possable or is there somthing else goin on? Thanks!
If you are in Spain, it is normal. If not please do the following in order to see if you're infected:
Click here to download HJTsetup.exe
  • Save HJTsetup.exe to your desktop.
  • Double click on the HJTsetup.exe icon on your desktop.
  • By default it will install to C:\Program Files\Hijack This.
  • Continue to click Next in the setup dialogue boxes until you get to the Select Additional Tasks dialogue.
  • Put a check by Create a desktop icon then click Next again.
  • Continue to follow the rest of the prompts from there.
  • At the final dialogue box click Finish and it will launch Hijack This.
  • Click on the Do a system scan and save a log file button. It will scan and then ask you to save the log.
  • Click Save to save the log file and then the log will open in notepad.
  • Click on "Edit > Select All" then click on "Edit > Copy" to copy the entire contents of the log.
  • Come back here to this thread and Paste the log in your next reply.
  • DO NOT have Hijack This fix anything yet. Most of what it finds will be harmless or even required.
Here is the log file from HJT hope it helps:
Logfile of HijackThis v1.99.1
Scan saved at 2:27:52 PM, on 3/30/2008
MSIE: Internet Explorer v7.00 (7.00.5730.0013)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
c:\program files\common files\logitech\lvmvfm\LVPrcSrv.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe
C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\CAPPActiveProtection.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
C:\Program Files\Hijackthis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: BitComet ClickCapture - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - G:\documents\program files\BitComet\tools\BitCometBHO_1.2.1.2.dll (file missing)
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O4 - HKLM\..\Run: [cctray] "C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe"
O4 - HKLM\..\Run: [CAVRID] "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe"
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O8 - Extra context menu item: &D&ownload &with BitComet - res://G:\documents\program files\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: &D&ownload all video with BitComet - res://G:\documents\program files\BitComet\BitComet.exe/AddVideo.htm
O8 - Extra context menu item: &D&ownload all with BitComet - res://G:\documents\program files\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: BitComet - {D18A0B52-D63C-4ed0-AFC6-C1E3DC1AF43A} - res://G:\documents\program files\BitComet\tools\BitCometBHO_1.2.1.2.dll/206 (file missing)
O11 - Options group: [INTERNATIONAL] International*
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/win...ls/en/x86/client/wuweb_site.cab?1191827677672
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/mic...ls/en/x86/client/muweb_site.cab?1191828510229
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: CaCCProvSP - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
O23 - Service: CAISafe - Computer Associates International, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
O23 - Service: Google Updater Service (gusvc) - Unknown owner - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe (file missing)
O23 - Service: CA Pest Patrol Realtime Protection Service (ITMRTSVC) - CA, Inc. - C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
O23 - Service: Process Monitor (LVPrcSrv) - Logitech Inc. - c:\program files\common files\logitech\lvmvfm\LVPrcSrv.exe
O23 - Service: LVSrvLauncher - Logitech Inc. - C:\Program Files\Common Files\Logitech\SrvLnch\SrvLnch.exe
O23 - Service: PPCtlPriv - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
O23 - Service: VET Message Service (VETMSGNT) - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
Ok your log shows no signs of infection.
Check the Internet settings of your browser, maybe you set it to be in Spanish or something.
If you are using Firefox, re-install it and see if it changes anything.
In Firefox try this:
Tools->Options->Main->Home Page. Erase what is written in Home Page and put: www.google.com Click on O.K. Close Firefox and open it again. Tell us if it went to google.com or google.es
Hm this is maybe it:
Please open your HIjackThis and click Do a system scan only.
Check this entry:
Close ALL OPEN WINDOWS except the HijackThis and click Fix checked.
Now reboot your computer...
Go to www.google.com...
Does the problem persist?
Check this entry:
Nope, this is normal :P
Google is supposed to redirect people to the appropriate regional site depending on their location. Try clicking on the "Google.com in English" - the setting should be saved for next time.
