Ok sure, Thanks a lot for the info!
It helped me claim back 20GB![]()
WOW!!!!!I'll do it now!
It isn't a Registry Cleaner type of thing, it shows you what files / folders are using the most space on your HDD, I just deleted what I didn't need![]()
What did you delete? Old restore points? Vista takes up alot of hdd for restore points!
what version of windows are you running, no need to run giant gui based applications. You can use built in features, like the command diruse to see how much space is being taken up.
Then delete it right there from the command line.
I just don't see the point of loading tons and tons of third party apps when you can just do it from the command line is all.
Thats it!
Thanks, PC_Eye!![]()
