Yeah you should see mine, it is not pretty. I wondered the same thing. How do people put the wires behind the mobo? I mean on mine there is probably only a 1/2 inch or less of space just by guessing. How do they fit the wires behind there?
There are holes in the plate underneath the mobo and you can route the wires through there.
Not with my case, I got a acrylic case similar to this one: http://www.xoxide.com/logisys-handcrafted-preassembled-acrylic-case.html
