A One-Port HTDV Cable amplifier. The single port EDA 2100 is designed to boost CATV signals by 15 dB over a single port. The EDA 2100 features an industry benchmark for low noise at 3 dB, and the extra surge protection (XSP) has been rated at the IEEE 6 kV 3 kA combination wave standard for enhanced lightning protection. This test injects 35 times more energy than the level found in previous models, and guarantees durability that will stand the test of time. A waterproof housing and SCTE compliant 360° F-terminals ensure a nearly indestructible design, as do short-circuit protected wall adapters. Power verification is provided by a built-in confirmation LED. 10-year manufacturer's warranty. Features and Specifications: *Number of ports: 1 *Forward gain: 15 dB *Return path insertion loss: 0.5 dB *Forward passband: 54-1000 MHz *Return passband: 5-65 MHz *Frequency response flatness: ±1 dB *Noise figure: 3 dB *RFI isolation: 100 dB minimum *Surge protection (IEEE C62.41-1991, all ports) ring wave: 6 kV, 500 A, loc. B3, combination wave: 6 kV, 3 kA, loc. B3 *Operating temperature: -40°F to 140°F (-40°C to +60°C).EDA-2100: A 1-port amplifier. One port amplifiers are the easiest to install, and are best suited for connecting to your incoming cable line before you start splitting off the line to go to multiple TVs. The EDA-2100 is generally the best for use in existing installations, since it is easy to use, with a single cable connection in and out.
