Windows XP task manager display issue
stuaz
Hey,
When i view Task Manager its missing the top tabs, which allow you to switch between processes and applications etc.
Also in the task bar at the bottom is missing the text which says "Task Manager" generally.
Please see my screen shots attached.
I have tried changing windows profile etc.
Its probably because of that theme your using,I got that when i used to apply diffrent themes.
as long as task manager is working fine i should leave it be ;)
Fixed it. If you double click in the top (grey area - not the list box) it expands and brings back the tabs and everything.
^^... no! I am a Vista wannabe! lol
Great! Another one!! Common guys save your money and actually buy it because its worth every penny!!! I dont know what I would do with out it.
No... I won't get Vista because it's hideous. The theme and all is great but the overall OS is really poorly made. I'll stick with my XP SP3.
If thats what you think!! Vista is way better than xp. Vista runs great here but i guess if you dont know how to opperate a pc then you should prob stick with xp!!
Isn't it really stupid that that can happen? I've had it happen to me and it's confused the hell outta me.
What kind of outrageous crack are you smoking? Vista is by all means a lot of times worst and more pathetic than XP. Infact, I'll stick to a Win 98 rather than Vista. And please, define how can I not know how to operate a PC? Vista was suppose to be even more easier for idiots so they can attract mac buyers.
I will stick with good old XP, got enough problems with my Vista Sony laptop!
I wish they gave me the option to have XP, the more stable OS imo.
If you are having problems with vista than most likely its your fault because i have had nothing less than a great time with it!! I love vista!!! You all just need to take the plunge and learn more about vista b/c its great. From a personal perspective i think vista is great and has come along way!! If you are having problems with vist taking too much memory than chances are you dont know how to manage a pc the right way!!
Haha very funny!! Im16 so I dont think I work for microsoft! DUH
Ahh that would explain the positive reaction to Vista. Wait till your out in the commercial world and then you will see the short falls of Vista.
Its a good idea in practice, but its to power hungry for commercial use at this time and from a business point of view (the ways i have to see things), there are not many benefits which validate upgrading from XP.
Then again, I'm a Linux man through and through!! Hahaha:D
"we" teenagers like the new, flashy, cool looking things. Vista is one of them. I was excited until I read the reviews about incompatibilities and other issues. I know to stay away from Vista for a long time.
I'm 17 BTW and I'm proud to say I'm sticking with XP.
I have not had any problems with compatibility yet! And i have alot of programs installed and games!!
