I am looking at spending $700 on a new system. Not for gaming, I was just wondering what you guys thought about set up and any substitutions you guys would make.
I would also like advice on a cash, I can't seem to find one I really like. I want something inexpensive, sleek and stylish, with a clear side panel, I dont really like the gaming ones. Thanks.
dvd burner
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-05 - OEM $33.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106073
dvd drive
LITE-ON Combo Black SATA Model DH-52C2S-04 - OEM $22.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106100
case:
Sunbeam IC-SS-US-SVBK Silver/Black Steel ATX Mid Tower Computer Case 450W Power Supply - Retail $64.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811166027
HDD:
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
Video card:
XFX PVT88SFDF4 GeForce 8800GS 384MB 192-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail $99 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150275
RAM:
Kingston HyperX 4GB(4 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Quad Kit Desktop Memory Model KHX8500D2K4/4G - Retail $121.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134596
Mobo:
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard - Retail $89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
CPU:
Intel Core 2 Duo E8200 Wolfdale 2.66GHz LGA 775 65W Dual-Core Processor Model EU80570PJ0676M - OEM $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115047
total: $718.92
dvd burner
dvd drive
case:
HDD:
Video card:
RAM:
Mobo:
CPU:
total: $718.92
