Intel Quad Core Gaming(need suggestions)
jblah
I'm building a new Quad Core computer within a month or 2. Just wanted to run it by people and get some feedback on it. Any suggestions and comments are more than welcomed. My "price" range is around $800 - $850 (preferably around $800 - 810). Computer will be mostly used for games like CSS, DODS, WOW and such aswell as some programming (SQL, C#, JAVA).
https://secure.newegg.com/NewVersio...mber=9654427&WishListTitle=New+Quad+Core+Wish
Decorations:
Sunbeam LL-B Blue LASER LED - Retail -- $2.99
http://www.newegg.com/product/product.aspx?item=N82E16800884026
Case:
RAIDMAX SMILODON ATX-612WBP Black SECC STEEL ATX Mid Tower Computer Case 500W Power Supply - Retail -- $94.99
http://www.newegg.com/product/product.aspx?item=N82E16811156062
Motherboard:
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard - Retail -- $89.99
http://www.newegg.com/product/product.aspx?item=N82E16813128059
Graphics Card:
EVGA 384-P3-N853-AR GeForce 8800GS Superclocked 384MB 192-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail -- $139.99
http://www.newegg.com/product/product.aspx?item=N82E16814130333
Power Supply:
Rosewill RP550-2 ATX12V v2.01 550W Power Supply -- $56.99
http://www.newegg.com/product/product.aspx?item=N82E16817182017
Processor:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model HH80562PH0568M - OEM -- $234.99
http://www.newegg.com/product/product.aspx?item=N82E16819115018
Memory:
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail -- $79.99
http://www.newegg.com/product/product.aspx?item=N82E16820231122
Hard Drive:
Seagate Barracuda 7200.10 ST3250310AS 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM -- $59.99
http://www.newegg.com/product/product.aspx?item=N82E16822148261
(will also add another 250 GB internal from my present computer and another 250GB External)
Drives:
Pioneer 20X DVD±R DVD Burner Black IDE Model DVR-115DBK - OEM -- $29.99
http://www.newegg.com/product/product.aspx?item=N82E16827129018
CPU Cooler:
MASSCOOL 8WA741 92mm Ball CPU Cooler - Retail -- $20.99
http://www.newegg.com/product/product.aspx?item=N82E16835150082
CPU Cooler - CPU Thermal compound (i've used this before..it works)
Arctic Silver 5 Thermal Compound - OEM -- $5.99
http://www.newegg.com/product/product.aspx?item=N82E16835100007
Total: $816.89
i'm going to use the 500W PS from the case as a backup in case the 550 W case fails.
any suggestions and comments are welcomed.
well u might as well get a case without a power supply if ur buying an additional one as well. Get a hard drive with 16 cache i have the 250gb seagate with 16 cache and its only 10 more bucks. Otherwise it looks like a nice build.
yes i did see that..can you tell me what the difference is? ..is it really that much faster? do u feel a difference?
also..i'm just worried from reading all the reviews about peoples power supply dying on them. thats why i guess i was going to get a backup. but i guess if your computer explodes..there isn't much a backup supply will help with.
forget the backup power supply. just buy something good.
forget that harddrive aswel.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152100
thats an amazing performance drive. 32mb cache and reviews put it no.1
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134028
get that graphics card.
buy this cpu.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115046
faster and can overclock to 4ghz.
it will hold its value so if you ever really need a quad core, then you can sell it. plus the q6600 will drop a huge amount in a few months when newer cores come out.
get this cpu cooler. the one you picked looks shíte!
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106069
hopefully it will fall in your budget.
its a lot more powerful and faster.
buy this cpu.
Thanks for the help. highly appreciate it. it seems just slightly over my budget.
The HD isn't a big issue to me. i have one 250 internal and another 250 external so added with the 250 that i'm going to buy..it'll be 750 either way. the ones i have now..aren't that slow so i'm ok with that as long as my primary 250 for the new one is fast.
i'll keep that graphics card in mind. its out of stock at the moment.
is the E8400 better than the quad? i guess how would i go about comparing those 2 CPU? why would the price of the quad go down after a few? This is something that i'm considering changing if i can find out more info.
yeah the cpu cooler that i got was relatively cheap thats why i got it. The one u got..looks neat but it has a circular base? how does that fit in with a processor? do you have that one? also it doesn't say core 2 duo as a compatibility.
i have one and it fits on perfectly. it had a wide base but your mobo doesnt have anything restrictive on it so your fine.
ok, get the harddrive you picked, but be sure to get that graphics card or any 8800gt 512mb if you want good gaming results.
that cpu has a higher clock, which means it runs at 3.0ghz. and has 2 cores. you could easily overclock that to 3.8ghz.
the quad core has 4, and can be over clocked to a decent 3.2ghz.
prices on everything go down a lot after a while. the q6600 has been around for a good while and will drop soon when intel start releasing large amounts of their new cpu's for cheaper. that causes the older chips to fall in price.
i wouldbe be surprised if the q6600 hit 150 bucks by the end of the summer.
if you dont get the harddrive, then you can afford the graphics and the cpu and cpu cooler.
yup making adjustment. i was just concerned slightly about the heatsink/fan. but if it works its great :) thanks once again for your help appreciate it.
good stuff. you should have an exceptionally fast powerful gaming machine once thats build
and for 800 bucks thats a friggin steal!
i priced it here in ireland where i live and cant find it cheaper than 1200 dollars.
Many games support only 2 cores only. Thus, the E8400 will beat the Q6600 in benchmarks. Future games will have quad core utilization, and when that comes, the Q6600 will step ahead and beat the E8400 in games. Still, the Q6600 is a perfect multitasking CPU.
