need help with logitch keyboard
Shane
Super Moderator
Hey all,
i have a Logitech ex110 cordless mouse and keyboard.
its fantastic,however as you may be able to see it has some grey buttons at the top which are play/pause,Stop,Next and back.
i tried pressing next to skiptracks in Windows media player using these buttons but they dont do anything?
anyone know why?
even in the logitch setpoint control panel i cant find any options for those buttons?
any help appreciated ;)
Make sure that you installed the software that came with it, or make sure that the program used to run them is enabled...
hi,
i have its called logitech setpoint software,however i see no options to enable those keys :cool:
Works fine here with Setpoint installed. Didn't even have to configure anything :confused: Same keyboard BTW...Don't use the supplied mouse though I hate it :P
although i didn't install the software it somehow was able to work with the media player classic addon of the klite codec pack
hmm thats weird,mine dont :cool: , why dont you use the mouse?
i find it quite accurate when playing cod4 :D
il give that a try and see if it works tks ;)
