MBGraphics
Ok guys, I have been debating on which LED's I should use on my case when I get it (NZXT Apollo "Black")
1. Use all blue (front, side, and rear fans all blue LED's, and all blue cathodes around the window
2. Use all red (front, side, and rear fans all red LED's, and all red cathodes around the window.
3. Use both! more red: front and rear fans Red LED's, with stock blue LED side fan. with red cathodes around the windows
4. use both! more blue: front and rear fans blue LED's with red side fan. and blue cathodes around the windows
5. mix it all around: stock side blue LED with front and rear red LED's. then 2 blue cathodes for top and bottom and 2 red cathodes for right and left around side window
6. OTHER: specify what you think
Basically what I will be doing is buying the Antec Tri-Cool LED fans for the front and rear (side also if i get all red) as well as 4 12" cathodes to fit around the side pannel window (top, bottom, right, and left)
Keep in mind, there WILL still be blue on the case because it has some lighting on it already and it only comes with blue
You can see pictures of them stock here: http://www.newegg.com/Product/ShowI...+Chassis+ATX+Mid+Tower+Computer+Case+-+Retail
Thanks in advanced for any help,
-Mike
-Mike
