Upgrade time
pbdr
So the time is almost upon us. I iwll be upgrading soon. My current choices are :
CPU: http://www.newegg.com/product/product.aspx?item=N82E16819115037 (I don't plan on overclocking, BTW)
MOBO:http://www.newegg.com/product/product.aspx?item=N82E16813128082 (I like the energy saver design) or this http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059 (it seems a good solid board)
RAM:http://www.newegg.com/product/product.aspx?item=N82E16820231166 (anyone hear of problems with this RAM and Gigabyte boards?)
The GPU, DVD, etc. will be those from my sig.
Feel free to critique and/or make alternate suggestions.
Awesome.
I have the P35-DS3R and it's awesome.! :D
My cousin has the P35-DSRL great if your not going to overclock or need more then 4 sata ports at once.
The processor is a good choice, unless you want to wait and spend more on the Q9450 or wait for the new socket from intel to come out. :P
P35-DS3L.
Watch your mouth! The P35-DS3L is a great overclocker. I have its cousin, the P31-DS3L. I doubt a "not going to overclock" board can get from 1.6GHz to 3GHz+
only 800 with a CL of 4 or 3 is faster
because the cl is lower it can cycle the data faster
OK, so because the latency is lower, it can cycle faster?
So would 4, 1gb sticks of CAS 3 be better then 2, 2gb sticks of CAS 4?
