I Got a Virus, Can't See Desktop Now
pboz99
Hi All,
I recently got a virus from a P2P site. I think it was a trojan horse. I updated my spyware/anti-virus software and cleaned my computer.
The internet is running fine now, but when I first turn the computer on my desktop icons only appear for about 2 seconds and then they all disappear. The start icon and the rest of the graphics that run along the bottom of the screen also disappear.
I am unable to access any of the files on my computer now. Does anyone know how I can restore my computer to normal? I would really appreciate the help!
Thank you in advance,
Pboz
try ctrl alt del then click on add new process followed by 'explore.exe' or 'explorer.exe' agh i forgot it was ages since i used windows p.s dont add ' in the command
Thanks! That helped. I can see them now, BUT now the icons and the bottom of the screen display flash on, then off over and over again. Do you know of a way to make that stop?
Do you use a mac now?
No I don't and yes I dont use a mac just the operating system
