surfshack66
even after changing my bios, i cannot get my dell to boot from cdrom, its a dimension 8400 and im reintalling windows xp cause it cant take vista that well
If the system there lacks an optional boot device menu and you have to set the cd rom as the first boot device simply disable anything else and remember to press any key when that comes up on the screen following the initial post tests. That will force the system to look to the optical drive for boot information and should see the installer load unless the drive or drive cable has a problem.
is the disc bootable?
