HI All,
I have question about something I have never tried. My new home brew Vista system is running two 500gB SATA drives in a RAID 1 configuration. My new MB only has one PATA port which I am using for CD and DVD drives.
My old XP drives still work and are sitting on a shelf. There are some files that I thought I had tranferred to the the new drives but I guess I didn't. I want to get them back.
My scheme is to disconnect the optical drives and plug in the old PATA drive. when I start the machine what can I expect? The old drive is a bootable XP disk but I don't want to boot from it.
I hope the machine will boot from the Vista disk and then find the PATA drive as new hardware and install the driver. Then maybe I can see the drive in Windows Explorer. If so, I should be able to simply drag the files over to the RAID drives and be done with it. Then I'll return to the original configuration with the optical drives.
Is this a realistic operation? Will there be trouble? Should I set the old PATA drive to be a slave? It will be the only device on the ATA bus.
Thanks, Sparky
Thanks, Sparky
