How to reinstall SONY Vaio computer?
jcfenfen
Hi,
I have a Sony Vaio PCV-RX550 desktop, I found that the cable connecting CD-rom, DVD-rom and hard disk is loose, but I don't know how to connect them back correctly. Also, there is a iron case structure that separates the Cd-ROM and DVD-rom from the rest of the components, and I don't know how to take them out of the case and reconnect the cable. The case seems pretty tough to get off. Can someone please help me?
1 cable connects all 3 drives? to reconnect all you do is plug in the wires in the correct orientation. before removing them note which wires go where. perhaps it would make it easier for you if you stick some tape on wires with a little reminder of where it goes before removing
for removing any drive all you need is a screwdriver.
maybe giving us pictures will help
Hi,
There is only one way to connect them back. They have litle tabs that prevent you from installing them backwards. Thhe iron case structure is supposed to be there. It does what you said, seperates them frome each other.
