hp pavilion zl1150 ?s
Sorry it might be zt1150
ok thats better. This lappy is perfect for browsing the internet. Not any intensive applications or anything though. WIRELESS internet wont really matter, its basically internet so no worries. If u wanna look up somehting on Wikipedia its perfect. U may need to buy Wireless adapter if u dont already have one. :D
Ok I am an idiot whats an adapter and where do i buy one , I plan on useing verizon since they are my cell company. Oh and thank you for your help!
Lets say you get verizon (or any other dsl/cable internet company). They will give you something called a MODEM:
You will plug the phone line witht he internet connection in the MODEM. The modem will have an ethernet connection (the yellow cable) that plugs into the computer. If u want wireless internet or u want the internet on more than one computer you get a wireless ROUTER:
the ethernet cable form ur modem will be removed from ur comp and will be plugged into this baby. After that u got wireless internet after a simple setup process. For wireless, some laptops come with adaptors built in (the newer ones). but urs definietly does not so you would need this:
usb
PCI
both will give u basically the samething. 2 diff flavors both the same thing though.
you plug these into the comp u want ur internet on. so thats it.
