CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115045&Tpk=E4700
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127333
X38 motherboards are expensive, so I suggest getting an SLI motherboard if you want dual video cards
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131232
9600GT scales very well in SLI better than the 8 series
What about this???
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813186116
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811146041
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
GPU / Video Card - http://www.newegg.com/Product/Product.aspx?Item=N82E16814121093
Hard Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136178
i hope this helps youand your friend
[-0MEGA-];955063 said:I got my system for $553 shipped, without a case or PSU, so add that up and you are looking at a nice build for around $900.
Thats nice. The thing is I live in Denmark and things are unfortunately more expensive over here.![]()
oh ok..... uumm.... have you got any computer sites over there. We can give you a build from one...
CPU
Motherboard
RAM
GPU
Yes. getmore.dk is the cheapest. But it is in danish.
