I'm looking for an ATI PCI-E graphics card, but I'm not sure what I should be looking at.
I checked out the top ATI PCI-E card on the ASUS site and I found these specs for it, the EAH3870/G/HTDI/512M (I'll post what seems important):
Video Memory: DDR4 512MB
Engine Clock: 775 MHz
Memory Clock: 2.25GHz (1.125GHz DDR4)
RAMDAC: 400MHZ
Memory Interface: 256-bit
DVI Max Resolution: 2560x1600
Card Size: 4.376 inches x 9 inches
What specs should I be concerned about? And... The comp I'm planning on making will have an ASUS Rampage Formula, Intel Core 2 Quad Q9550, 4 GB DDR2 (not sure what brand though), and I haven't decided on a case, but I have a list of them to choose from (will have at least 3 120mm fans). Will the comp I'm building support this card? What really bothers me is the DDR4 spec for the graphics card, becaue the Rampage Formula mobo only has DDR2. Also, some of these ATI PCI-E cards have fans and heatsink, but I might use a GPU waterblock, so I'm wondering can I remove these fans and heatsinks? Thanks in advance for answering.
RAMDAC: 400MHZ
