monster of a computer???
bigjj92
AMD® Athlon™ X2 6400+ 3.2GHz Dual Core 2 x 1MB L2 Cache
Alienware® 1000 Watt Multi-GPU Approved Power Supply
1GB ATI® Radeon™ HD 3870 X2 – Dual GPU Technology
2GB Dual Channel DDR2 SDRAM at 800MHz - 2 x 1024MB
Windows Vista® Home Premium
20X Dual-Layer Burner (DVD±RW)
Killer K1 Gaming Network Interface Card
High-Definition 7.1 Performance Audio
19" Samsung 953BW – 1440 x 900 (2ms) Widescreen Flat Panel
:confused: is it a good setup?
First of all, welcome to the forum! :)
On topic:
Yes except for the processor, not too beastie IMO.
How much is it?
is this any better?
AMD® Phenom™ X4 9850 Black Edition Quad Core 2.5GHz 4 x 512KB L2 Cache
o and its
Well, depends on what you're gonna use the comp for. Since it's Alienware, I'd like to think it's for gaming so really it's not gonna help that much over the Athlon X2 6000+
:eek:
I would suggest you buy it from somewhere else. That computer is not worth more than $1500. Alienware is way overpriced. Have you thought about Dell? Of course, if money is not a problem, go ahead with Alienware.
As a side question, would you be interested in building it yourself?
:eek:
i would love to build one but im not that good in computers myself thats why im going alienware. money is not problem for this
Well, then I guess that Alienware with the Phenom is the best option.
Now, as far as I know, Alienware does not make comps based on Intel processors (which are currently more efficient than AMD). So if you really want a good gaming rig and money is not an option, I'd recommend a Dell XPS Gaming comp instead or a pre-built comp from Newegg.
Maybe something like this:
Comp:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883227052
Monitor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001094
TOTAL w/Shipping: $1566.45 US
And WAY better than that Alienware comp ;)
Building a computer is really easy, It's not all that technical actually. Just plug everythig in the only way it fits. :D
Yeah, it's pretty easy actually. If you want to, theres even two guides (with steps+pictures) on this forum for building a computer. ;)
I'm going to have to agree, building is fairly easy and it is rewarding... At the least it is worth looking into.
agree with whats been said about building a computer.
every part comes with a diagram on how to install each part.
if your not confident enough to do it, go to newegg and buy a pre built computer.
2,500 will buy you a monster of a computer compared to that alienware piece of crap.
1) Without the brand of the NIC, we can't tell you if it's quality or crap.
2) Get 4GB, either 4x 1GB or 2x 2GB
3) Go Intel.
