Building a rig for a friend of mine, and I roughly searched around newegg for parts and came up with a list. His budget was about $600 US, but I wanted to check up if the list was fine first. So here are the links to the parts.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106228
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133216
http://www.newegg.com/Product/Product.aspx?Item=N82E16820141241
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185125
As you can see, I haven't picked out a PSU or Case yet. I'm not exactly sure which PSU would be suitable for this computer, so any good recommendations would be helpful. Same thing with the case as well. I'm also a little iffy about an ram as well, but he does want 4 gigs.
I think it leaves him with about 80-90 bucks to spend for the PSU and the case, but if anyone has any other suggestions for a different set-up, that's good too. Thanks for any help!
