help with internet browser
americandelight
hello
i have a problem with my internet browser n if anyone could help me i would be happy. whenever i scroll my mouse, drag the sidebar or the arrow key, the page goes one line by one refreshing itself (like there is a line runnin all the way through from top to bottom as each line goes down). this happens even if i click the pagedn or up button. it takes ages to scroll this way.
i tried changin the settings in my browser as well in the internet options(smooth scrolling) but it doesnt work.
if anyone could help me ill be very thankful:(
thanx in advance
ps: just now i found out that not only my browser but everything on the screen goes skippin that way. i mean when i have a restored window moved from one plave to another on the screen it keeps blinkin that way n that way it takes a lot of time to move (there is this line as i said earlier which runs from top to down like it seems to refresh itself) somebody please help me!!!!!!!!!!!!!!!!!
hi
this is a new dell laptop(inspiron ) and it had windows vista as its operating system . i was so used to xp so i changed the os to xp pro. when it was as vista it worked fine. i dont know if this has to do anything with changing the os.
an additional info---i did some trouble shooting n they asked me change the "hardware acceleration " to none in the 'troubleshoot' tab which is under the settings for display properties. which was earlier set to "full"
now it seems to be better but still doesnt seem to scroll fast (cos the configuration is very good-intel core 2 duo, 3.50 gb of ram)
please tell me if i can make it right anyother way.
thanx
you need to install the correct video driver for XP now. Go to dell's support site and select xp as operating system and you can download the correct video driver for it. What Inspiron model do you have?
Download a new Graphic Driver. It could be that an update from Microsoft Windows that has caused the Graphic driver to mess up. What version of Vista (32bit or 64bit) are you using and what graphic chip (nvidia/ATI/Intel) is inside the laptop?
In fact, if you link me to the dell website and the laptop you've got, then I will link you to the correct drivers.
hello
thanx for the reply, im posting the link of my computer its the third one with price tag 999 euro, i searched for the graphic card "nVidia® GeForce™ Go 8600M GT " for the operating system xp but i didnt find it in their website. but the driver for the vista os is available. i dont know if my card will only be suitable with vista. if so then im in deep problem cos i work a lot with autocad n 3dsmax n i dont like vista interface. please help me.
http://www1.euro.dell.com/content/p...s.aspx/inspnnb_1720?c=fr&cs=frdhs1&l=fr&s=dhs
Ok found this on Dell support website. The following drivers are for nVidia GeForce 8400M, GeForce 8400M GS, GeForce 8600M, Driver, Windows XP, Multi Language, Inspiron 1420, 1520, 1720, v.174.31 xp WHQL, A07
The following link will take you straight to the driver required:http://ftp.us.dell.com/video/R180917.exe
Hope that helps
hi
i have done the same way n made the resolution to 1440 x 900 pixels. it seems to work perfect. now the hardware acceletation is to "full". but still when i watch pictures the edges appear to be jagged. but im very very happy with what u have suggested me. atleast i dont have to wait ages to scroll down my pages. big hugs to u"jammiedodger".
thanx
hi
thanx
how do you mean by that in bold above?! is it the movies or every including the text on screen...
You may need to increase the "anti-aliasing". What that does is, it remove (or at least) improve the jagged edges round every thing. To do that, there should be an nVidia icon on the system taskbar (in the bottom right corner), click that icon and a small sub-menu will come up, look for anti-aliasing and increase that to the highest it can go...but remember, the highest you go, the more performance from the GPU is required.;)
hi
i entered the nvidia control panel but didnt find anythin named "anti-aliasing". but instead i changed the "flat panel setting " to the native resolution of "1440 x 900" n the "edge enhancement" by 50 % n now it seems to be more sharp than before.
im very happy. bissous
