C computeruler New Member May 8, 2008 #21 it will if you put the resevior and other stuff outside of the case
morris14cc New Member May 8, 2008 #22 so is it better to get the external liquid cooling then? what do i have to do when i go through security with this at an airport?
morris14cc New Member May 9, 2008 #23 morris14cc said: so is it better to get the external liquid cooling then? what do i have to do when i go through security with this at an airport? Click to expand... ?
morris14cc New Member May 12, 2008 #25 does this mobo support 45nm cpus? http://www.newegg.com/product/product.aspx?item=N82E16813131237
morris14cc New Member May 12, 2008 #26 will 8800GTS fit? http://www.newegg.com/product/product.aspx?item=N82E16811144223
morris14cc New Member May 12, 2008 #27 or will this? http://www.newegg.com/product/product.aspx?item=N82E16811133044
tlarkin VIP Member May 12, 2008 #28 You ever hear of google? Not trying to be rude but if I were to answer your questions I would be googling them.
O oscaryu1 VIP Member May 13, 2008 #29 Lanbox? Not sure. If it would, it would be a VERY tight fit. I wouldn't trust any PSU that's included with the case.
