New case :D:D
Yeah, I want to see the optical drive button :)
I'm seriously selling my Apollo case just to mod an Elite 330!! :D
*edit* I want to mod a Lian-Li PC-7B instead of the Elite 330 :D :D
i dont need a button all i did was double side tape the cover on my drive with some sanding down the back first and pushed the drive back all i do to open it is just hit the side of the cover
Here is a picture of the dvd drive button
And i got some feet today, or should i say wheels ?? :P
taylormsj, that is a kick-ass case. I want to get it but I hear from some reviews that the side panel vibrates and that fans that come with it make a humming sound. Is that true? Would you recommend it?
looks pretty cool have you considered stealthing your fan contoller too?
Yep i plan on doing it next week, i only got it yesterday
Cant hear any vibrations on the panels, as long as they are screwed on using the supplied thumbscrews, the fans that come with the case i find do not make a humming sound, they arent silent though :(
The only thing i dont like about the case is the motherboard tray, its pretty thin metal, its not a problem, just make sure you dont lean on it or drop somthing in the middle of it
Thanks for the comments guys
I just added a pic of my open drives into my "Computer" album. (Link in signature)
Nice Voyager! And how do you open it? did you make a button like Taylor?
Well, I can only really open them in windows because I use a program called "CD Tray Pal" and allows you to configure keystrokes to open them. (Mine are Ctrl and the drive letter) so if I'm in Linux (Which I don't use much) I have to pry the bottom up and use a pencil to hit the button.
Oh cool. I think I'm more into the button thing. :D
I could always find something to place behind the cover so I can just press the side corner and it'll open. (Kinda like the new Dell's and eMachines)
