Computer Will Not Boot
Download the proper SP1? Huh, I got it through a MS Update...
Jim, It's the same problem I was having with my old HDD, I had RAM Memtest and ChkDsk on that, and it didn't find any problems... Thanks though!
I remember that before I put my new HDD in, my old one hadn't done it for a good while, So, I'll try putting that back in and see if it does it... Then, If it doesn't, format my current one and use it as a secondary... *sigh* :cool:
Would I just plug the old one in, then once it's booted, plug the new one in and formatt it through Windows?
Well i say it is SP1 and that there is a fault with it! So maybe don't install SP1... until you hear good reports about it!
time for an old fashioned reinstall? i cant remember if you can still get to all your files, but maybe back them up on the other hard drive and just do a fresh install. if thats an option.
I had this problem on my other HDD (120GB SATA II WD) and on my new HDD (500GB SATA II Seagate Barracuda)... I remember that my old drive hadn't done it for a while, so, at the moment, I'm trying that one out, to see if it does it...
If it doesn't, I'll use the 500GB as a secondary and install stuff on that, as it's a lot faster, just keep my OS and Files on the 120GB WD.
It still BSOD's on me... I'm really running out of ideas! :mad:
At the moment, I have both HDD's in there, the old WD with the OS on and the new Seagate as a secondary.
For some reason, I cannot format my Seagate HDD. I right clicked on it in 'My Computer' Clicked 'Format' and it gets to the end, after a good while, and says "Windows Cannot Complete the Format"...
I restarted my computer and got an 0x00001A BSOD on start-up.
I've had so many different BSOD's;
0x00008A
0x000019
0x00000A
0x0000C5
I'm starting to think it's hardware related as it does it with a fresh install?
I really, really, don't know what to do... May just sell my whole computer! Forget it, Wast of ****** time!
