9600GT good ?
jutnm
anyone with the 9600GT have good experience with the card, what are ur thoughts on it ? i dont think ill need the power of 9800GTX in my system, so i switch my mind, but is it a good card ?
It is a very good card from everywhere I have looked. The card was made for intermediate gamers looking for a decent card.
It's okay, but there are probably better choices. For a bit more you could get the 8800GS (almost equal), or for a bit more you could get the 8800GT which is quite a bit better.
Or, if you want to go REALLY crazy...
3x 9800GTX's in Tri-Sli!
:P
well what do u suggest for under $250 and that is compatible for PCIe 1.0 and has to be nVidia. can u do me a little shoppin, me mom asks what i want for senior grad present :D but not to expensive :P
thanks
You could ofcourse get two 9600GT's that are used? They give a great SLI boost from what I saw. Though you'd have to get an SLI-mobo first...
