The_Beast
I didn't really mod it too much I just painted from the standard white
Side panel sanded down to the metal
The other panel and top sand to the metal
Sorry I didn't get pics to the paint job in progress
Side panel painted
Side and top panel
Close up of the vent
The front painted(I left the 3.5" and the 5" bays along with the power and reset buttons unpainted because I'm thinking of painting them Fire Red)
Close up of the shiney front
All the panels and front are primed, painted and clear coated with a "rattle" can paint. The paint job cost a whopping $4.03 (.97 primer, $1.94 of paint [2 cans] and $1.12 for clear coat). Ohh yeah I spend $5 for a wire drill brush. I spent more on the brush then the paint job
Here is a pic of the internals of the case
Side panel painted
Side and top panel
