I'm still not sure what you are asking. I don't know what you mean as sign on as administrator. In any event, what I did is boot the computer to the welcome screen where there are the 3 icons that I mentioned above. I clicked on the one that said Frank and then I clicked on the desktop icon Combofix to run the scan. After completion the text doc popped up. Here are the results:
ComboFix 08-05-15.3 - Frank 2008-05-20 8:25:36.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.1363 [GMT -4:00]
Running from: J:\ComboFix.exe
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\WINDOWS\system32\JjlSBJlm.ini
C:\WINDOWS\system32\JjlSBJlm.ini2
((((((((((((((((((((((((( Files Created from 2008-04-20 to 2008-05-20 )))))))))))))))))))))))))))))))
2008-05-19 14:24 . 2008-05-19 14:25 1,024 --ah----- C:\WINDOWS\system32\config\systemprofile\ntuser.dat.LOG
2008-05-19 07:26 . 2008-05-19 07:26 <DIR> d-------- C:\Program Files\Trend Micro
2008-05-18 21:47 . 2008-05-18 21:47 <DIR> d-------- C:\Documents and Settings\Guest\Application Data\Panasonic
2008-05-18 21:47 . 2008-05-18 21:47 <DIR> d-------- C:\Documents and Settings\Guest\Application Data\AVG7
2008-05-18 21:42 . 2008-05-18 21:42 <DIR> d-------- C:\Documents and Settings\Problem correction\Application Data\Panasonic
2008-05-18 21:42 . 2008-05-18 21:42 <DIR> d-------- C:\Documents and Settings\Problem correction\Application Data\AVG7
2008-05-18 18:47 . 2007-09-06 00:22 289,144 --a------ C:\WINDOWS\system32\VCCLSID.exe
2008-05-18 18:47 . 2006-04-27 17:49 288,417 --a------ C:\WINDOWS\system32\SrchSTS.exe
2008-05-18 18:47 . 2008-05-15 23:22 86,528 --a------ C:\WINDOWS\system32\VACFix.exe
2008-05-18 18:47 . 2008-04-28 08:03 82,944 --a------ C:\WINDOWS\system32\IEDFix.exe
2008-05-18 18:47 . 2008-04-28 08:03 82,944 --a------ C:\WINDOWS\system32\404Fix.exe
2008-05-18 18:47 . 2003-06-05 21:13 53,248 --a------ C:\WINDOWS\system32\Process.exe
2008-05-18 18:47 . 2004-07-31 18:50 51,200 --a------ C:\WINDOWS\system32\dumphive.exe
2008-05-18 18:47 . 2007-10-04 00:36 25,600 --a------ C:\WINDOWS\system32\WS2Fix.exe
2008-05-18 15:24 . 2008-05-18 15:24 1,390,340 --a------ C:\SmitfraudFix.exe
2008-05-18 13:40 . 2008-05-18 18:48 3,050 --a------ C:\WINDOWS\system32\tmp.reg
2008-05-18 13:28 . 2008-05-18 13:28 <DIR> d-------- C:\Documents and Settings\Guest
2008-05-18 13:28 . 2008-05-20 08:29 1,024 --ah----- C:\Documents and Settings\Guest\ntuser.dat.LOG
2008-05-18 13:20 . 2006-02-28 08:00 221,184 --a------ C:\WINDOWS\system32\wmpns.dll
2008-05-18 13:19 . 2008-05-18 13:19 <DIR> d-------- C:\Documents and Settings\Problem correction
2008-05-18 13:19 . 2008-05-20 08:29 1,024 --ah----- C:\Documents and Settings\Problem correction\ntuser.dat.LOG
2008-05-18 10:53 . 2008-05-18 10:53 319,872 --a------ C:\WINDOWS\system32\mlJBSljJ.dll
2008-05-18 10:48 . 2008-05-18 10:48 <DIR> dr-h----- C:\$VAULT$.AVG
2008-05-18 10:48 . 2008-05-17 17:14 286,720 --a------ C:\WINDOWS\pxgdslro.dll
2008-05-18 10:48 . 2008-05-17 17:15 245,760 --a------ C:\WINDOWS\nldfmtappek.dll
2008-05-18 10:48 . 2008-05-18 10:48 28,800 --a------ C:\WINDOWS\system32\cbXQkhFu.dll
2008-05-07 17:43 . 2008-05-08 13:51 <DIR> d-------- C:\Program Files\Avalon Health Care
2008-05-03 11:53 . 2008-05-03 11:53 <DIR> d-------- C:\Program Files\Common Files\xing shared
2008-05-03 11:52 . 2008-05-03 11:53 <DIR> d-------- C:\Program Files\Common Files\Real
2008-05-03 11:50 . 2008-05-03 11:50 <DIR> d-------- C:\Program Files\Real
2008-04-28 11:21 . 2008-04-28 11:21 <DIR> d-------- C:\Program Files\SiteChallenge
2008-04-28 11:21 . 2007-05-03 10:15 68,496 --a------ C:\WINDOWS\system32\MLSecurityCOM.dll
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-05-20 04:02 --------- d-----w C:\Program Files\LogMeIn
2008-05-18 14:52 --------- d-----w C:\Documents and Settings\All Users\Application Data\avg7
2008-05-17 13:12 --------- d-----w C:\Program Files\COMODO
2008-05-17 13:12 --------- d-----w C:\Documents and Settings\Frank\Application Data\Comodo
2008-05-12 15:34 --------- d-----w C:\Documents and Settings\Frank\Application Data\AdobeUM
2008-04-15 12:09 1,880 ----a-w C:\WINDOWS\AUTOLNCH.REG
2008-04-02 15:27 --------- d-----w C:\Program Files\Microsoft Works
2008-03-30 14:44 --------- d-----w C:\Program Files\2nd Story Software
((((((((((((((((((((((((((((( snapshot@2008-05-19_14.30.16.78 )))))))))))))))))))))))))))))))))))))))))
- 2008-05-19 18:28:46 2,048 --s-a-w C:\WINDOWS\bootstat.dat
+ 2008-05-20 12:29:04 2,048 --s-a-w C:\WINDOWS\bootstat.dat
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{47551F98-CC7F-4701-A650-D7231EEA60BD}]
2008-05-18 10:48 28800 --a------ C:\WINDOWS\system32\cbXQkhFu.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{E2937F69-9299-4609-AD57-536278226A08}]
2008-05-18 10:53 319872 --a------ C:\WINDOWS\system32\mlJBSljJ.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"AVG7_CC"="C:\PROGRA~1\Grisoft\AVG7\avgcc.exe" [2008-04-15 08:15 579584]
"HP Lamp"="C:\Program Files\Hewlett-Packard\HP PrecisionScan\PrecisionScan Pro\hplamp.exe" [2001-04-27 12:00 53248]
"type32"="C:\Program Files\Microsoft IntelliType Pro\type32.exe" [2005-03-15 05:46 196608]
"IntelliPoint"="C:\Program Files\Microsoft IntelliPoint\point32.exe" [2005-03-23 19:26 217088]
"nwiz"="nwiz.exe" [2007-06-28 12:43 1626112 C:\WINDOWS\system32\nwiz.exe]
"PaperPort PTD"="C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe" [2003-09-06 01:16 57393]
"IndexSearch"="C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe" [2003-09-06 01:35 40960]
"NvCplDaemon"="C:\WINDOWS\system32\NvCpl.dll" [2007-06-28 12:43 8466432]
"Panasonic Device Monitor Wakeup"="C:\Program Files\Panasonic\Device Monitor\dmwakeup.exe" [2006-11-02 15:54 303104]
"Panasonic Device Manager for Multi-Function Station software"="C:\Program Files\Panasonic\MFStation\PCCMFSDM.exe" [2007-05-21 13:46 126976]
"Panasonic PCFAX for Multi-Function Station software"="C:\Program Files\Panasonic\MFStation\KmPcFax.exe" [2007-05-29 11:31 757760]
"TkBellExe"="C:\Program Files\Common Files\Real\Update_OB\realsched.exe" [2008-05-03 11:52 185896]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"AVG7_Run"="C:\PROGRA~1\Grisoft\AVG7\avgw.exe" [2007-12-02 11:19 219136]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Adobe Reader Speed Launch.lnk - C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-09-23 23:05:26 29696]
Device Detector 3.lnk - C:\Program Files\Olympus\DeviceDetector\DevDtct2.exe [2007-12-16 02:47:49 114688]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\explorer]
"NoResolveSearch"= 1 (0x1)
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\shellexecutehooks]
"{A213B520-C6C2-11d0-AF9D-008029E1027E}"= C:\Program Files\Symantec\WinFax\WfxSeh32.Dll [1998-07-27 05:54 38400]
"{47551F98-CC7F-4701-A650-D7231EEA60BD}"= C:\WINDOWS\system32\cbXQkhFu.dll [2008-05-18 10:48 28800]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\cbXQkhFu]
cbXQkhFu.dll 2008-05-18 10:48 28800 C:\WINDOWS\system32\cbXQkhFu.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\LMIinit]
LMIinit.dll 2007-11-15 19:46 87352 C:\WINDOWS\system32\LMIinit.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
"AppInit_DLLs"=
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
"VIDC.YV12"= yv12vfw.dll
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
backup=C:\WINDOWS\pss\Microsoft Office.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Service Manager.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Service Manager.lnk
backup=C:\WINDOWS\pss\Service Manager.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Alcmtr]
--a------ 2005-05-03 11:43 69632 C:\WINDOWS\Alcmtr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ControlCenter2.0]
--------- 2005-01-07 18:30 864256 C:\Program Files\Brother\ControlCenter2\brctrcen.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
--a------ 2006-02-28 08:00 15360 C:\WINDOWS\system32\ctfmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LogMeIn GUI]
--a------ 2007-08-03 16:09 63048 C:\Program Files\LogMeIn\x86\LogMeInSystray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
--a------ 2007-06-28 12:43 8466432 C:\WINDOWS\system32\NvCpl.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoboForm]
--a------ 2007-12-05 11:47 160592 C:\Program Files\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoxioDragToDisc]
--a------ 2003-07-18 18:23 868352 C:\Program Files\Roxio\Easy CD Creator 6\DragToDisc\DrgToDsc.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoxioEngineUtility]
--a------ 2003-05-01 19:44 65536 C:\Program Files\Common Files\Roxio Shared\System\EngUtil.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RTHDCPL]
--a------ 2006-06-01 09:48 16208384 C:\WINDOWS\RTHDCPL.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SetDefPrt]
--------- 2004-11-11 18:14 49152 C:\Program Files\Brother\Brmfl04g\BrStDvPt.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SkyTel]
--a------ 2006-05-16 11:04 2879488 C:\WINDOWS\SkyTel.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SSBkgdUpdate]
--a------ 2006-09-28 14:16 185896 C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WinFaxAppPortStarter]
--a------ 2000-02-14 18:36 43008 C:\WINDOWS\system32\WFXSNT40.EXE
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
"BITS"=2 (0x2)
"WZCSVC"=2 (0x2)
"W32Time"=2 (0x2)
"CiSvc"=3 (0x3)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"C:\\Program Files\\Grisoft\\AVG7\\avginet.exe"=
"C:\\Program Files\\Grisoft\\AVG7\\avgamsvr.exe"=
"C:\\Program Files\\Grisoft\\AVG7\\avgcc.exe"=
"C:\\Program Files\\Grisoft\\AVG7\\avgemc.exe"=
"C:\\WINDOWS\\system32\\usmt\\migwiz.exe"=
"C:\\Program Files\\Panasonic\\TrapMonitor\\Trapmnnt.exe"=
"C:\\Program Files\\VideoLAN\\VLC\\vlc.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"3389:TCP"= 3389:TCP
xpsp2res.dll,-22009
R2 LMIInfo;LogMeIn Kernel Information Provider;C:\Program Files\LogMeIn\x86\RaInfo.sys [2007-08-03 16:09]
R2 LMIRfsDriver;LogMeIn Remote File System Driver;C:\WINDOWS\system32\drivers\LMIRfsDriver.sys [2007-08-03 16:09]
R2 Panasonic Local Printer Service;Panasonic Local Printer Service;C:\PROGRA~1\PANASO~1\LocalCom\lmsrvnt.exe [2004-08-03 05:33]
S3 brfilt;Brother MFC Filter Driver;C:\WINDOWS\system32\Drivers\Brfilt.sys [2001-08-17 14:12]
S3 brparimg;Brother Multi Function Parallel Image driver;C:\WINDOWS\system32\DRIVERS\BrParImg.sys [2001-08-17 14:12]
S3 BrParWdm;Brother WDM Parallel Driver;C:\WINDOWS\system32\Drivers\BrParwdm.sys [2001-08-17 14:12]
S3 BrSerWDM;Brother WDM Serial driver;C:\WINDOWS\system32\Drivers\BrSerWdm.sys [2004-11-23 18:39]
S4 wfxsvc;WinFax PRO;C:\WINDOWS\system32\WFXSVC.EXE [2000-02-14 18:36]
disk not found C:\
please note that you need administrator rights to perform deep scan
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
disk not found C:\
scan completed successfully
hidden files:
--------------------- DLLs Loaded Under Running Processes ---------------------
PROCESS: C:\WINDOWS\system32\winlogon.exe
-> C:\WINDOWS\system32\cbXQkhFu.dll
------------------------ Other Running Processes ------------------------
C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
C:\WINDOWS\system32\BRSS01A.EXE
C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
C:\WINDOWS\system32\BrmfBAgS.exe
C:\Program Files\LogMeIn\x86\ramaint.exe
C:\Program Files\LogMeIn\x86\LogMeIn.exe
C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTSMLBIZ\Binn\sqlservr.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\PROGRA~1\PANASO~1\TRAPMO~1\Trapmnnt.exe
C:\WINDOWS\system32\wdfmgr.exe
C:\WINDOWS\system32\MsPMSPSv.exe
Completion time: 2008-05-20 8:31:13 - machine was rebooted
ComboFix-quarantined-files.txt 2008-05-20 12:31:08
ComboFix2.txt 2008-05-19 18:30:33
Pre-Run: 280,088,997,888 bytes free
Post-Run: 280,074,104,832 bytes free
237 --- E O F --- 2008-05-18 19:42:34
