Problem BIG BLUE SCREEN
memooo
I have a problem in mp PC sometimes my PC stops and a blue screen pop up and it said many thing i don't understand it says "IRQ_AND......" and in the end it says "Beginning dump of physical memory...." i don't remember all of it, and sometimes my PC restart automatically without any reason just like that :eek:
So can anyone tell me what is happening is it a problem in my RAM, HDD or CPU?
PLEASE
Heres my dxdiag information
like this picture except for "PAGE_FAL..." "IRQ_AND..." (Not my picture found it)
MY PC:
Intel Pentium 4 (2CPU) 3000 MHz
1GB RAM DDR1 "Zeppelin"
NVIDIA GeForce 6200 256MB DDR2
Internal: 80GB HDD "Western Digital" + 40GB HDD "Samsung"
External: 500GB HDD "SeaGate"
YAH it's a little old
The first thing to do when seeing any blue screen is take notes on as much information as you can and pay attention to see if the name of any device or software driver is shown. In XP there's a registry value you can set from "1" to "0" to keep the crash control from seeing the system restart while being something for the advanced user there.
The SPCMDCON.SYS file is the thing to look at there being the mini command console in both 2000 and XP alike. Since you posted the actual blue screen that helped identify the system file causing the problem or lack of it if missing or corrupted somehow.
You could try the system file checker with the XP cd in the optical drive with the "sfc /scannow" command entered at the Run prompt. But the best results you are likely to see would be manually expanding the replacement from the I386 folder on the installation disk while booted up to the recovery console.
For seeing a replacement file expanded say D is for the optical drive you would type in at the prompt: "D:>expand I386\spcmdcon.sy_ C:\Windows\system32" and press the enter button. The uderscore is seen instead of the second "s" on sys files extension since the file is still compressed in a cab file there.
the irql_not_less_or_equal code thing for me, meant that my cpu was overheating.
thats exctly what shown in the blue screen
"IRQL_NOT_LESS_OR_EQUAL"
what is that means and in the end says "tcpip.sys"
what is that? is it because the power supply problem cuz i put a power supply not the one came with the PC:confused:
ah and yes sometime when i turn off my PC like for 9 hours and start turn it on it takes time until my PC starts or sometimes i have to unplug the cable of the power supply and plug it in then tada it works and the windows starts, then after that the blue screen pop up or my PC restart and keep restarting and if i got lucky the PC start work normally.
Is the problem in my power supply or my CPU cuz i really don't know what to do? and if the problem in my power supply i will go and buy a new one.
NEED HELP PLEASE
NEED HELP PLEASE
The tcpip.sys error is a system driver type file found in the system32 folder and can be optionally started or stopped by going into the Control Panel to open up the services section. Using the system file checker with the XP disk in the drive could likely see that replaced.
The alternative is to boot upto the recovery console when booting off of the XP installation disk and selecting the R for repair option in order to manually see a replacement file expanded from the I386 folder on the disk when at the command line prompt seen there. Windows problems as well as a bad supply can see a number of items like constant restarts. How long has this copy of Windows been running since the initial installation?
